[SOLVED] Problem with the mobile version
I have a problem with my mobile version.
The Top a module are not at the good place.
If I cancel Top a, it does the same with Top b.
And my menu is not on my website. I put it on "offcanvas" module.
Have a look please : www.chaletdespres.ch
Thanks
Thanks
by groug
Please publish a logo on module position "logo-small" too.
Ok, it is done... But always the problem
by groug
please check your syntax in your top-a modules.
There must be an issue.
Otherwise please give us admin account and we will check it.
www.joomlaplates.com/contact-us
I send you my access by the form
Thanks
Thanks
by groug
yes I saw your data and I have fixed the problem. It was a bug which is fixed in theme version 1.0.002
I have send you an email, but the mail address was wrong.
The following user(s) said Thank You: groug
