[SOLVED] Galeria isn't installing in the right way
I bought the Galeria template and just followed the description to install it. I have hosting space at Strato.nl (.de)
I distracted the zip file and copied the content to my hosting space in a seperate directory. At my provider I created a database.
After that I called my website (rugbyinbeeld.nl) and started the installation proces. Everything goes well and everything is green.
When I'm ready it says, it has installed a blog, but the galeria template hasn't been installed. So I do a manually installation of the galeria template zip file.
After that, I did the installation of the "blog demo content" because there isn't any other demo content.
When I log in at my website I only see a blog login (I even made the Galeria template the default). and nothing else.
Can anyone help me? Am I doing something wrong?
by Marcel57
Hi Marcel,
maybe you forget to activate the option "install sample content" during the installation process ?!
joomlaplates-installation link
Greetings,
Christian
Greetings,
Christian
Last Edit:6 years 3 weeks ago
by cg
Last edit: 6 years 3 weeks ago by cg.
Replied by Marcel57 on topic Galeria isn't installing in the right way
Posted 6 years 3 weeks ago #21934
Hello Christian,
I didn't see that option during the installation proces. Only after the installation the possibility to install the blog demo content.
Where should I see that option?
by Marcel57
im working with joomla!
Please look at the linked joomlaplates Readme: www.joomlaplates.com/support/documentation/install-demo-content
There you find a hint to this option.
Sorry, when you have forgotten to activate this option (see readme above) then you have to install your template again.
Christian
Christian
by cg
Posted 6 years 3 weeks ago #21936
Hello Christian,
I'm now copying the extracted files to my webspace again to do a clean install.
One question, I assume when i"m copying all the quickstart files to my webspace that's allright?
Or do I also have to extract the separate jp-galeria.zip file and copy those files also to the webspace? And if so, to what location?
Thanks for your help so far!
by Marcel57
as I remember the rough installation steps are:
- Create the database
- upload your quickstart.zip on your webspace
- Then if your hoster allows it, decompress the file
- an then run the install.php (don't forget the option for installing the demo-content !!!)
by cg
