[SOLVED] Rokcommon / Rok Sproket
- richardstehle
- Junior Boarder
I need to update RokSprocket Module from 2.1.23 to 2.1.25
I downloaded wp_rokcommon-3.2.6.zip alreday.
With the extensions/install utility with joomla 3.9 i can not uüdate this module.
Warnung
JInstaller: :Install: Die Joomla!-XML-Installationsdatei konnte nicht gefunden werden.
Fehler
Es kann kein Installationspaket gefunden werden!
What can i do??
best regards
Richard
Warnung
Fehler
What can i do??
best regards
Richard
wp_rokcommon-3.2.6.zip is for Wordpress!
www.joomlaplates.com/forum/important-mes...cket-update-problems
- richardstehle
- Junior Boarder
OK, i did so.
Now i Get an error message on one page:
Warning: count(): Parameter must be an array or an object that implements Countable in C:\xampp7.2\apps\joomla\htdocs\templates\promark\roksprocket\layouts\mosaic\themes\default\index.php on line 19
Whats wrong here?
Thanks for your assistance.
Best regards
Richard
Whats wrong here?
Best regards
Richard
this is not one of our theme > Promark
Attachment Screenshot_3-2-3-4-5-6-7-8-9-10-11-12-13-14-15-16-17-18-19-20-21-22-23-24-25-26-27-28-29-30-31-32-33-34-35-36-37-38-39-40-41-42.jpg not found
- richardstehle
- Junior Boarder
I copied the SOUNDS Template to "promark" before i made modifications (colours etc.)
Please use the org theme name otherwise you are getting problems with the folders.
