[SOLVED] Menu Home Always Highlighted
Wondering how to configure the menu on this template so that the Home button is not always highlighted. If I select any menu item, it will become highlighted, but the Home will stay highlighted, too.
by dlong
Hello dlong,
i use the chrome browser.
In the demo version of MAXIMUM the problem does not seem to occur (see the attached file).
by cg
The Home stays highlighted even in Chrome on my site. I see that the demo doesn't behave this way, and wonder how I can get the same result.
by dlong
Hello dlong,
here the quick and dirty solution:
.class-assigned-to-the-menue .uk-navbar-nav > li.uk-active > a {
background-color: #222222; /* nearly black */
color: #ffffff; /* better to change combined with background-color */
Last Edit:5 years 11 months ago
by cg
Last edit: 5 years 11 months ago by cg.
The following user(s) said Thank You: Mock
Thanks, cg. I added the snippet into the custom.css file, but it has no effect. Where does it need to go?
by dlong
You add the page class:
See:
www.joomlaplates.com/forum/search?query=...0class&childforums=1
The Posts are in german but the hardcopies are self explanatory.
by cg
