[SOLVED] How to change from vertical to horizontal menù
Hi guys,
I have just bought the template.
I have one problem about the main menù in position 'top_main'... it is displayed in vertical but I want to have it in an horizontal position.
I have tried to put in module setting 'nav-pills' (with space before) but nothing is changed...
How can I fix it?
  • cg
  • cg's Avatar Offline
  • Gold Boarder
  • Gold Boarder
  • Thank you received: 53
Replied by cg on topic How to change from vertical to horizontal menù
Posted 5 years 11 months ago #22206
Hi Stefano,
in the Demo-Version of Folio the menu is horizontal as required.
I think your menu-items are too long.
Greetings,
cg
Last Edit:5 years 11 months ago by cg
Last edit: 5 years 11 months ago by cg.
Replied by Stefano Guida Meloni on topic How to change from vertical to horizontal menù
Posted 5 years 11 months ago #22207
Hi Cg,
also with small menu-items is still the same...
Attachment menùproblem-2.jpg not found
  • cg
  • Gold Boarder
  • Gold Boarder
Posted 5 years 11 months ago #22212
Hi Stefano,
the site is not online yet?
by cg
  • cg
  • Gold Boarder
  • Gold Boarder
Posted 5 years 11 months ago #22235
Hi Stefano,
add the following code to your custom.css.
As you see in the attached picture, my browser (chrome) shows the menu-items horizontal.
Make a test in Firefox and IE too.
ul.uk-nav.uk-nav-parent-icon.uk-nav-side { display: -webkit-box; display: -ms-flexbox; display: flex; }
