Login background section
Can you help me to change the background from the login menu link?
by dairo
Yes sorry! Here it is:
Login form: neuroinstitute.mx/index.php/2011-05-02-12-32-40
It also happens at the end of the contact form here: neuroinstitute.mx/index.php/contacto
by dairo
Your booking extension is loading another bootstrap version and thats the reason why.
Please add this code to your css/custom.css to fix the form background
.well {
background: none !impoartant
hello again. I think I messed up something. While I was waiting for the answer on how to change the background I tried to do it by myself changing the "background" in the customization for the form. I went to Customization my own template -> Form -> background -> and I just insert the number of RGB color I wanted and suddenly I can not enter anymore to the customization link
I didn't click save or anything after I input the number value, the page just refreshed and now I can get this message every time I try to enter again "LESS Runtime error."
by dairo
Delete the created style and create a new style with customizer.
And just insert the HEX code into the background field
