[SOLVED] Large gaps between modules
Replied by joomlaplates on topic Large gaps between modules
Posted 6 years 2 months ago #25594
You say: Only published modules are shown in the Modul manager. If you want to add a module position.
Just insert a name and press "return"
www.joomlaplates.com/support/documentation/warp-7-modules
The space can be reduced in the theme options > settings > layout
Attachment gap-2.jpg not found
Replied by alainchammas on topic [SOLVED] Large gaps between modules
Posted 6 years 4 weeks ago #26075
