[SOLVED] Large gaps between modules
Large gaps between modules was created by alainchammas
Posted 4 years 11 months ago #25359
The website is www.afriquesure.org .
I am trying to get rid of the large blank space and line between the end of the text and the sponsors logo row, and again between the sponsors logo row and the map. How do I do that?
Also, I haven't been able to center the iFrame with the map at the bottom, any suggestions?
Thank you very much for all your efforts, und Frohe Weihnachten,
Alain Chammas
Replied by joomlaplates on topic Large gaps between modules
Posted 4 years 10 months ago #25367
1.) You can change the gap ( padding) at the Template settings > Layouts > Bottom-C > See image
Attachment padding-2.jpg not found
2.) Please use this instructions to add a map
www.joomlaplates.com/support/documentation/setup-a-google-map
>> max-width is important
The following user(s) said Thank You: alainchammas
Replied by alainchammas on topic Large gaps between modules
Posted 4 years 10 months ago #25570
Follow-up on the previous question:
How do I reduce gaps around any module position (e.g. Headerbar, but any other would also be useful).
Also, how do I make a module position (not the module itself) not show at all on a page?
Not all the module positions show in the list where I edited Section Bottom D...
Best regards,
Alain Chammas
Posted 4 years 10 months ago #25576
Template Settings > Options > Module > Your Module > Style = Blank
Only published modules are shown in the Modul manager. If you want to add a module position.
Just insert a name and press "return"
Posted 4 years 10 months ago #25579
Hello again,
Sorry to get back on this.
You say: Only published modules are shown in the Modul manager. If you want to add a module position.
Where do I insert the name of the module position to publish it?
I searched the interface and the warp7 docs, and couldn’t find a reference to this.
Best regards,
Alain
Posted 4 years 10 months ago #25592
Hello again,
The website in question is afriquesure.org. If you go there you will see right away what I am talking about: spacing between menu and the search bar, between the search bar and the article body, between the bottom of the article and the sponsor logo row. Any suggestions?
Best regards, und vielen Dank,
Alain
