[SOLVED] Set color for inactive Menu items
Set color for inactive Menu items was created by cesarsupport
Posted 4 years 10 months ago #25425
Hello.
I need help to achieve the following:
How can I change the color of inactive items from Navbar without changing the background color?
Example
nav background:#fff
nav hover background : #3974ac
nav active background: :#3974ac
¿ nav inactive background: :#000 ?
If it is not possible to define the color of inactive items, how to reduce the width of the navbar, so that the black background does not affect the logo.
Kind regards.
Last Edit:4 years 10 months ago by cesarsupport
Last edit: 4 years 10 months ago by cesarsupport.
Replied by joomlaplates on topic Set color for active Menu items
Posted 4 years 10 months ago #25428
What do you mean with "inactive items".
All menu item must be shown, otherwise you cant click them!
You can reduce the space between the menu items in Customizer > Advanced > Navbar > Advanced > Padding
Last Edit:4 years 10 months ago by joomlaplates
Last edit: 4 years 10 months ago by joomlaplates.
Replied by cesarsupport on topic Set color for active Menu items
Posted 4 years 10 months ago #25445
Thank you, what I want to achieve is that the background of the menu bar does not affect the logo.
Posted 4 years 10 months ago #25449
Make your logo image with a white background, thats much more easilier
Posted 4 years 10 months ago #25453
Hello.
I can put an image with a white background.
But I would like to define the maximum width of Navbar and keep the align to the right.
Replied by cesarsupport on topic Set color for inactive Menu items
Posted 4 years 10 months ago #25460
I finally made it with css.
I appreciate your time.
Kind regards.
