[SOLVED] Navbar
I have two questions:
1) How do I stop the navbar from dropping down when scrolling down the page?
2) Is it possible to insert an image in the Navbar background instead of a colour?
Thanks.
Thanks.
by Jayoosk
1.) Template Options > Settings > Layout > Sticky Menu = OFF
2.) Its possible, but not just with one click. CSS know how is needed
www.joomlaplates.com/support/documentation/theme-customizing
Hello, make sure if not any other layout is using the "Fixed Navigation"
Therefore check the other layouts
How the layouts are working, Video ( Very helpful, please watch)
www.joomlaplates.com/support/documentation/warp-7-layouts
Attachment layouts-2-3-4-5-6-7-8-9-10-11-12-13-14.jpg not found
