Article in home page not visible
Other problem: I set the menu item "home page" with the "smooth scroll function". I edit the absolute module in home, and the top-a module, but nothing happens...
Can you help me? thanks!
Replied by joomlaplates on topic Article in home page not visible
Posted 4 years 7 months ago #27384www.joomlaplates.de/dokumentation.html
Posted 4 years 7 months ago #27385www.joomlaplates.de/dokumentation.html
thanks!
Posted 4 years 7 months ago #27390The layout settings manage the positioning of different layout parts.
This section makes the arrangement of your content very easy and flexible. You can enable or disable system output, define the layout of the theme's widget or module positions and select a style you created in the customizer. Additionally you have the possibility to store your modifications in a layout profile and assign it to different pages.
Thanks,
J.
