[SOLVED] Problemns with uikit module
I have some problems with two uikit module. The first module is uikit-timeline. I couldn't change any colors. I solved the problems by adding to css/custom.css:
see picture 1
I'm not sure it's a good way to solve this problem.
The second module is uikit-grid-portfolio. When i click on image, everithing disappear as you can see at the bottom of this page www.reyser.fr/a-propos and on picture 2 and 3.
My template is easy 1.3.1 with astroid 2.5.4
uikit plugin 3.5.20
uikit timeline 1.2.0
uikit grid-portfolio 1.2.0
thanks
.uikit-timeline .uikit-timeline-item {
color: black;}
uikit plugin 3.5.20
thanks
by reyser
1.) Color chnage of the timeline is ok if you chnage it in custom.css. Dont touch the original files, because they will be ovderwritten
2.) Please update the Grid Portfolio to 1.2.1, and this issue depends on your Tags. The Tags must have no special characters or empty spaces.
For testing, please disable the Tags
Ok,
But where do i find Grid Portfolio to 1.2.1? I just find 1.2.0 in download section.
by reyser
Hello, sorry I was wrong.
Grid Portfolio is existing only in 1.2.0.
Try this
Try this
Hello, please add a headline, becaus the headline is used for Modalbox ID
Attachment uikit-grid.jpg not found
