Display of search index front end, buttons moved and larger than input line
Display of search index front end, buttons moved and larger than input line was created by WM-Loose
Posted 3 years 3 weeks ago #30453
Hello support team, the buttons (on the right, search and advanced search) are displayed larger than the input line. Is there a solution for this? Joomla 4.1.0 | tp_power 1.3.7 | Astroid 2.5.15
Last Edit:3 years 2 weeks ago
Last edit: 3 years 2 weeks ago by WM-Loose.
Replied by joomlaplates on topic Display of search index front end, buttons moved and larger than input line
Posted 3 years 3 weeks ago #30455
Hallo, dass geht wie folgt:
1.) Joomla System > Site Templates > Template auswählen
2.) Editor Tab > html > mod_search > default.php auswählen
3.) Nun btn-sm hinzufügen ( siehe Bild)
Replied by WM-Loose on topic Display of search index front end, buttons moved and larger than input line
Posted 3 years 2 weeks ago #30467
Posted 3 years 2 weeks ago #30468
Live url dann.
Posted 3 years 2 weeks ago #30469
OK
Posted 3 years 2 weeks ago #30470
If youre using the search component instead of the search module you have to change the file html/com_search.. and not the file html/mod_search/...
Last edit: 3 years 2 weeks ago by joomlaplates.
