[GELÖST] Recent posts
  • mtplt
[GELÖST] Recent posts was created by mtplt
Posted 2 years 2 months ago #32353
Sorry for asking this simple question. I'm using the 'Life' template.
I want to use a slider or grid of recent post on my Home page, can I do it with Uikit? or what module should I use?
thanks again for all the help!
by mtplt
Replied by WM-Loose on topic [GELÖST] Recent posts
Posted 2 years 2 months ago #32355
Many users use Article Grid or Article Slider for this.
Article Grid
demo.joomlaplates.de/uikit/uikit-3-grid/...-3-article-grid.html
Article Slider:
demo.joomlaplates.de/uikit/uikit-3-slide...-article-slider.html
  • mtplt
Replied by mtplt on topic [GELÖST] Recent posts
Posted 2 years 2 months ago #32360
Hi Dirk,
When setting up UiKit 3 Article Grid: I create a new module, uikit grid, and then it seems that I have to add each post under 'Elements', is that right?
I don't want to manually assign posts there, what I'm trying to achieve is to post to be added automatically as new posts come in. Do you know if I can do that?
by mtplt
Posted 2 years 2 months ago #32362
All you have to do is assign the desired posts to a category (i.e. create a category beforehand) and then select the category in the plugin. Every post that you then create and assign to the category will automatically appear the way you want it.
  • mtplt
Posted 2 years 2 months ago #32364
Hi Dirk,
I honestly can not find that Category option for the plugin/module configuration. I just updated Uikit but still can't see that
by mtplt
Posted 2 years 2 months ago #32365
You need to download the right plugin.
It seems you are currently using simple grid and not article grid.
The following user(s) said Thank You: mtplt
