[SOLVED] Menu links not working in Adventure Template
[SOLVED] Menu links not working in Adventure Template was created by Jacks
Posted 2 years 1 month ago #32484
I have been setting up the menu in the adventure template for my website and linking single articles to each menu item. When I test the menu items on the front end I get a 404 error. Any suggestions about fixing this issue is much appreciated.
by Jacks
- Thank you received: 118
Replied by Administrator on topic [SOLVED] Menu links not working in Adventure Template
Posted 2 years 1 month ago #32488
Did you rename the htaccess.txt to .htaccess?
And did you activate the 'Rewrite Rule' at the Backend of Joomla?
Replied by joomlaplates on topic [SOLVED] Menu links not working in Adventure Template
Posted 2 years 1 month ago #32489Dokumentation:
Replied by Jacks on topic [SOLVED] Menu links not working in Adventure Template
Posted 2 years 1 month ago #32498
Thanks for the help but I still have the issue. I have done the things you mentioned as you will see in the screenshot attached. The menu links are still not working. Do I need to ask the server administrator to do something at their end?
by Jacks
Posted 2 years 1 month ago #32499
And did you set one of the menuepoints to 'home'?
If not, we need an url.
Last Edit:2 years 1 month ago
Last edit: 2 years 1 month ago by Administrator.
Posted 2 years 1 month ago #32504Did you rename the htaccess.txt to .htaccess?
Thank yiu for your response.
I did renamed the htaccess as suggested. I did set menu point to home. Menu still not working and I get a 404 not found Should I share the url here or via email?
by Jacks
