[SOLVED] CSS issues
Replied by WM-Loose on topic [SOLVED] CSS issues
Posted 2 years 8 months ago #33251
That would bring nothing, since it is probably because of the server configuration. This would break our support.
  • agrepe
Replied by agrepe on topic [SOLVED] CSS issues
Posted 2 years 8 months ago #33252
Thanks for your response.
My servers are all installed in exactly the same way with a master and a single script, I don't understand why it's only with Joomlaplates Templates that this problem occurs.
best regrads.
Eric
by agrepe
Replied by joomlaplates on topic [SOLVED] CSS issues
Posted 2 years 8 months ago #33253
Eric give me access to your site I will install the template.
Email me url/username/pass via mail
www.joomlaplates.com/contact.html
  • agrepe
Posted 2 years 8 months ago #33254
Thank You
Never post any pass in public forum
Best regards.
Eric
Last Edit:2 years 8 months ago by agrepe
Last edit: 2 years 8 months ago by joomlaplates.
Posted 2 years 8 months ago #33255
Hello Eric its a server problem or something else.
I cant even update the Joomla version
Last Edit:2 years 8 months ago by joomlaplates
  • agrepe
Posted 2 years 8 months ago #33259
Good morning sir,
I deleted all content on the server.
I installed a Joomla 4.3.1, (on a Debian 11 server, Apache 2, php 8.1, PhpMyAdmin 5.2.1) from the Joomla installation, there is no problem.
I again removed all the content, then proceeded to install from the Template GYM 1.3.14 full package and the problem reappeared.
The origin of the problem comes from full package.
Best regards.
Eric
by agrepe
