[SOLVED] UIkit 3 Grid Portfolio - "Limit" problem
Hi, after adding about 20 elements to UIkit 3 Grid Portfolio module I got error saying that some limits was exceeded. After some tests I discovered that there must be "module code" chart limit in entire module.
How to change that limit? Where I can do that? Or how to add more content to one Grid Portfolio module?
Regards.
Regards.
by karaspr
Replied by WM-Loose on topic UIkit 3 Grid Portfolio - "Limit" problem
Posted 1 week 3 days ago #35160
There is no limitation in the module. It seems to be more related to the server settings. Unfortunately, you have not provided any information about your Joomla version or PHP. We need more information.
Joomla-Version?
Grid-Portfolio-Version?
PHP-Version?
and thus the values used there for:
Upload Max Filesize ?M
Post Max Size ?M
Storage Limit ?M
BTW: Check your webspace to see if there are enough MB available
Joomla-Version?
PHP-Version?
Post Max Size ?M
Storage Limit ?M
Last Edit:1 week 3 days ago
Last edit: 1 week 3 days ago by WM-Loose.
Replied by karaspr on topic UIkit 3 Grid Portfolio - "Limit" problem
Posted 1 week 3 days ago #35163
Here are requested details:
- Joomla version: 4.4.8
- PHP version: 8.2
- UIkit 3 Grid Portfolio: 1.2.4
- Upload Max Filesize: 10 MB changed to 20 with no effect
- Post Max Size: 256M
- Storage Limit: way more than all my files
I wrote previously about chart limit because when you create another and another portfolio element you finally reach some limit and red Joomla popup "Save failed with the following error: The content exceeds allowed limits". And then if you adjust last element content length (ex. Custom HTML field) you can reach a moment when adding any letter to a title or content of ANY portfolio element gives error as mentioned.
- PHP version: 8.2
by karaspr
Last edit: 1 week 3 days ago by karaspr.
Posted 1 week 2 days ago #35167
any hint?
by karaspr
Posted 1 week 1 day ago #35170
I have now created 50 elements and not a single error.
We cannot help you further and I still suspect that the server-side settings are incorrect.
It is not a bug!
It is not a bug!
Posted 1 week 2 hours ago #35179
Ok, thank you. Can you try with elements filled with some amount of text and all with 10-15 large images?
Last Edit:1 week 2 hours ago
by karaspr
Last edit: 1 week 2 hours ago by karaspr.
