[SOLVED] license
1.) If you buy a template for 25.- euros you can use this theme only on 1 domain
2.) If you join a startup membership its allowed to use 3 templates
But you can not upgrade a membership from startup to advanced. If you upgrade your startuo to advanced you will loose the startup month.
- FernandoXD
- Junior Boarder
Hi, I have 3 sites in one domain, can I use 1 template for the 3 sites without lost the others 2 templates license?
EXAMPLE:
start.domain.com - [Bike's Template]
firstsite.domain.com - [Bike's Template]
secondsite.domain.com - [Bike's Template]
EXAMPLE:
by FernandoXD
You need one license for each domain.
If you have a starter subscription you have the license to use 3 templates.
It doesnt matter if you are using one template for three domains or 3 templates for 3 domains.
- FernandoXD
- Junior Boarder
Yes, i have starter membership.
Then, I can the 3 templates, one in each domanin, regardless of the number of subdomains?
joomlaplates wrote: You need one license for each domain.
by FernandoXD
