[SOLVED] license
Hello!
Sorry, I write through the translator!
The question is under license "Starter". It is not clear.
1. I can download 3 templates and install them on 3 domain?
For example:
"Bistro" - 1 website
"hi-fi" - 1 website
"Bike" - 1 website
2. Or each template separately, I can put on 3 domain?
For example:
"Bistro" - 3 website
"hi-fi" - 3 website
"Bike" - 3 website
For example:
"hi-fi" - 1 website
"Bike" - 1 website
For example:
"hi-fi" - 3 website
"Bike" - 3 website
Last Edit:9 years 9 months ago
by gorod3922
Last edit: 9 years 9 months ago by gorod3922.
This is the right one:
But you can download "all" template and test them on local Server."Bistro" - 1 website
"hi-fi" - 1 website
"Bike" - 1 website
Last edit: 9 years 9 months ago by joomlaplates.
You are allowed to make any changes and modifications in the themes or products to adapt them to your needs. It is not permitted to change or remove the copyright information in the source code. This includes the XML descriptor file and all PHP, JavaScript, HTML and CSS files distributed with our products. Of course, any visual copyrights, for example the copyrights in the theme footer, can be removed.
Do I understand correctly that I can remove the copyright? Marked on the picture in red
ibox.mamont-techno.ru/images/onepage.png
by gorod3922
Yes youre right the copyright on the frontpage can be removed.
