reduce space between two position
  • kabrito_22
  • Topic Author
reduce space between two position was created by kabrito_22
Posted 11 years 10 months ago #5899
how do I reduce the space between the end of slidertop and the begin of breadcrumbs ?
by kabrito_22
Replied by joomlaplates on topic reduce space between two position
Posted 11 years 10 months ago #5900
Live Url please and a screenshot!
1.) Watch this video > www.joomlaplates.com/template-customizing
2.) Analyze the margin or padding
3.) Reduce the margin or padding and then insert the the changed margin or padding into your custom.css
  • kabrito_22
  • Topic Author
Replied by kabrito_22 on topic reduce space between two position
Posted 11 years 10 months ago #5908
i insert this code in custom.css
div {margin-top: 0px} and not reduce enough. the margin actualy is 75 px
my site www.ciidept.net/portal/
by kabrito_22
Posted 11 years 10 months ago #5909
Add this code to your custom.css
.main-outer {padding:0}
#breadcrumbs {margin-top:0;margin-bottom:0}
  • kabrito_22
  • Topic Author
Posted 11 years 10 months ago #5940
already entered this code and not have change the space of the slidertop and breadcrums is 75px.
by kabrito_22
Posted 11 years 10 months ago #5944
The gaps are the "padding" from your jnews module, see image attached.
Please learn how to use the Firebug!!
And the slider can be set to zero gap with module clas suffix = mod-blank
Attachment margin.jpg not found
The following user(s) said Thank You: kabrito_22
