[SOLVED] h3 module top-a
  • Vlad
h3 module top-a was created by Vlad
Posted 11 years 6 months ago #7131
How to assign a h2 instead of h3 in the module top-a, top-b, top-c, top-d,
by Vlad
Replied by joomlaplates on topic h3 module top-a
Posted 11 years 6 months ago #7133
Hi Vlad,
the "h3" is the module title. If you dont want to use the "h3" module title you have to disable the tile and insert
a "h2" manually into your custom module.
2. Option
Modify the php file:
templates\jp-1stclass\layouts\widget.php
and replace the h3 with h2 shown below.
Attachment h3.jpg not found
After you have replace the h3 with h2 you have to create a new style for the "h2" too:
h2.uk-panel-title {}
Last Edit:11 years 6 months ago by joomlaplates
Last edit: 11 years 6 months ago by joomlaplates.
  • Vlad
Replied by Vlad on topic h3 module top-a
Posted 11 years 6 months ago #7138
after changes:
1. prior to
2. after
how to make the text was in the middle, as in the first case?
by Vlad
Posted 11 years 6 months ago #7139
Hi Vlad, as I told you before > You have to change the "h3" style at the css to your custom "h2" style too.
If you want to change the headlines you got more troubles then it´s worth.
Add this code below to your file: css/custom.css
.headline-border h2.uk-panel-title::before {
margin-left: -50%;
right: 0.5em;
.headline-border h2.uk-panel-title::before, .headline-border h2.uk-panel-title::after {
background-color: #000;
content: "";
display: inline-block;
height: 1px;
position: relative;
vertical-align: middle;
width: 50%;
left: 0.5em;
margin-right: -50%;
content: "";
height: 1px;
position: relative;
width: 50%;
.headline-border h2.uk-panel-title {
font-size: 200%;
overflow: hidden;
padding: 20px 0;
text-align: center;
The following user(s) said Thank You: Vlad
  • Vlad
Replied by Vlad on topic [SOLVED] h3 module top-a
Posted 11 years 6 months ago #7140
by Vlad
