[SOLVED] Customizer
  • gnjurac
  • gnjurac's Avatar Offline Topic Author
Customizer was created by gnjurac
Posted 9 years 4 months ago #8793
In my Customizer some attributes i can not change, i installed template(not quickstart) on joomla 3.4.3.
Thanks
by gnjurac
Replied by joomlaplates on topic Customizer
Posted 9 years 4 months ago #8797
What do you mean with "can not chnaged"?
Is there a grey "@". You can insert any code into the grey "@" because its just a placeholder
  • gnjurac
Replied by gnjurac on topic Customizer
Posted 9 years 4 months ago #8799
When i enter customizer background of navbar is loosing color and became transparent and when i change color nothing is happend.
by gnjurac
Posted 9 years 4 months ago #8800
1.) Please never edit the default style ( copy the default and customize it)
2.) Make sure that you have insert a "HEX" code and not rgb with any transparency
Attachment navbar.jpg not found
  • gnjurac
Posted 9 years 4 months ago #8801
I did that and nothing is changed
by gnjurac
Posted 9 years 4 months ago #8805
Hi there, admin access and url please.
Send it to support@joomlaplates.com
