[SOLVED] Customizer
Replied by alertas@burriana.es on topic Customizer
Posted 9 years 9 months ago #8828
If you comment the line 80 of the file joomlaplates.css you will see the color of the menu.
I had the same problem and I solved it.
Inside the file css/joomlaplates.css find .uk-navbar and then put /* at the beginning and put */ at the ending.
You can see in this example.
.uk-navbar {
/* background: none!important;*/
The following user(s) said Thank You: gnjurac
Replied by gnjurac on topic [SOLVED] Customizer
Posted 9 years 9 months ago #8829
by gnjurac
Replied by gnjurac on topic Customizer
Posted 9 years 9 months ago #8830
alertas@burriana.es wrote: If you comment the line 80 of the file joomlaplates.css you will see the color of the menu.
.uk-navbar {
Solved,
Thanks
by gnjurac
