Problems with Customizer
  • maxman1695
  • Topic Author
Problems with Customizer was created by maxman1695
Posted 10 years 9 months ago #8825
Hi all,
i want to customize the background a little bit.
So i tried to work with the Customizer. This problems are happened:
1) I work in the Customizer and the logo position (triangle) move to the left. (not more in the middle) [Screenshot "Logo Problem"]
2) Another problem, the footer changed the color to the background color - where can I change only footer color? [Screenshot "Footer Problem"]
But to the footer, i found a resolution in your topics , i added following code in Custom.css and footer color stay black:
".tm-footer {
background: none repeat scroll 0 0 #222;
color: #999;"
-> But i want to change the color over the customizer, if this possible?
3) Another problem, how i can change the width of the main content, I never see any size settings. -> where are this?
I hope you can help me, thanks a lot!
Best Regards,
Max
by maxman1695
