[SOLVED] Problems with menu in mobile mode
Replied by joomlaplates on topic Problems with menu in mobile mode
Posted 9 years 5 months ago #10634
please provide me Joomla admin access and I will check that.
Use our SSL contact form to send us the data.
Which size do you prefer?
Last Edit:9 years 5 months ago by joomlaplates
Last edit: 9 years 5 months ago by joomlaplates.
Replied by TorstenL on topic Problems with menu in mobile mode
Posted 9 years 5 months ago #10635
got no preferences regarding the size, all I want is that it shows correctly on tablets :)
Where can I find the SSL form? Also, the changes should be made to my live site.
BRgds
Torsten
Last Edit:9 years 5 months ago by TorstenL
Last edit: 9 years 5 months ago by TorstenL.
Posted 9 years 5 months ago #10637
Ok, I think I found a solution for you:
Add this code to your css/custom.css
@media all and (max-width: 968px) {
#jp-left {position: relative!important; width: 100% !important; }
#jp-left .inner { position: relative; top: 0px; left: 0px; margin: 0px; width: 100%!important; padding: 50px 0; text-align: left; height: auto; }
#jp-right { position: relative; width: 100%!important; margin: 0px auto!important; height: auto; }
@media all and (max-width: 480px) {
#jp-right { width: 100%; }
And now set the small max width to: 968px too
Attachment small.jpg not found
Posted 9 years 5 months ago #10639
Great, the menu is showing correct now in landscape mode. Only thing is that I can only see my forehead (see attach "Landscape.jpg") in the background pic, is there a way to change that so that die eyes are visible, too (see attach "Portrait.jpg")?
Many thanks in advance
Torsten
Posted 9 years 5 months ago #10640
Sorry thats not possible because the image is a full size background image.
The following user(s) said Thank You: TorstenL
Posted 9 years 4 months ago #10647
Thanks again, Peter, for your help. Mobile menu is working perfectly now :)
