[SOLVED] Ui Kit .. how work?
Ui Kit .. how work? was created by Ferriero
Posted 10 years 1 month ago #12168
Hi!
I tried to insert a tab element whit Ui Kit...
<ul class="uk-tab" data-uk-tab>
<li class="uk-active"><a href="">...</a></li>
<li><a href="">...</a></li>
<li class="uk-disabled"><a href="">...</a></li>
</ul>
Where can I insert the text to display for each tab?
Sorry for my ignorance! Thanks!
Replied by joomlaplates on topic Ui Kit .. how work?
Posted 10 years 1 month ago #12173
Here we are
<li class="uk-active"><a href="">TAB 1</a>Here goes your text</li>
<li><a href="">TAB 2</a>Here goes your text</li>
</ul>
Last Edit:10 years 1 month ago by joomlaplates
Last edit: 10 years 1 month ago by joomlaplates.
Replied by Ferriero on topic Ui Kit .. how work?
Posted 10 years 1 month ago #12176
Here the result... in attachment...
I can select TAB1 or TAB2, but the text is allways "Here goes your textHere goes your text"
Why?
Posted 10 years 1 month ago #12177
The Tab needs the switscher too:
getuikit.com/docs/switcher.html
<ul data-uk-tab="{connect:'#tab-content'}" class="uk-tab">
<li class="" aria-expanded="false">
<a href="#">Tab</a>
</li>
<li aria-expanded="false" class="">
<a href="#">Tab</a>
</li>
<li aria-expanded="true" class="uk-active">
<a href="#">Tab</a>
</li>
<li class="uk-tab-responsive uk-active uk-hidden" aria-haspopup="true" aria-expanded="false">
<a>Tab</a>
<div class="uk-dropdown uk-dropdown-small">
<ul class="uk-nav uk-nav-dropdown"></ul>
<div></div>
</div>
</li>
</ul>
<ul class="uk-switcher uk-margin" id="tab-content">
<li class="" aria-hidden="true">Hello!</li>
<li aria-hidden="true" class="">Hello again!</li>
<li aria-hidden="false" class="uk-active">Bazinga!</li>
</ul>
The following user(s) said Thank You: Ferriero
Replied by Ferriero on topic [SOLVED] Ui Kit .. how work?
Posted 10 years 1 month ago #12199
