[SOLVED] RokSprocket v2.1.9 alt tags
Hi
I am trying to insert alt tags into our images to help with SEO.
All images are inserted using RokSprocket v2.1.9 modules either in the header bar or in the grid content.
There is nowhere to access the code in these modules to input the alt tag.
Can you please advise how I can do this?
I know if an image is inserted into an article it can be done there, in the source code.
However for the styling of our site we have to have the headerbar on each page, either as a slider or a single static image.
Please advise, thanks.
by pacfood
Hi there, which layout?
Slideshow or mosaic ?
Hi
Some pics are in the slideshow, (headerbar).
The other pics are in the grid content, not sure if this is mosaic? Please see attached pictures for confirmation, thanks.
by pacfood
you can add the "alt" text manually, therefore you have to edit our override:
Add this code below to "alt=""
The override can be found at:
Joomla/templates/your theme/roksprocket/layouts/grids/themes/basic/item.php
<?php echo $item->getPrimaryImage()->getAlttext(); ?>
Attachment alt-text.jpg not found
Ok thanks, I will have a look.
by pacfood
Hi
I have added this to a test site and am not too sure if it is correct.
Please see the code image attached.
If yes it does not seem to alter anything. Please advise.
by pacfood
