[SOLVED] RokSprocket v2.1.9 alt tags
Replied by joomlaplates on topic RokSprocket v2.1.9 alt tags
Posted 10 years 2 weeks ago #12247
Yes the code seems to be ok.
Which file did you customized?
Live Url to your site please!
Replied by pacfood on topic RokSprocket v2.1.9 alt tags
Posted 10 years 2 weeks ago #12273
File customised: Joomla/templates/your theme/roksprocket/layouts/grids/themes/basic/item.php
URL: www.pacfood.com.au/Joomla/
I am not sure where to add the alt tag in the back end.
cheers
by pacfood
Posted 10 years 2 weeks ago #12274
sorry it was my fail.
The "alt" image tags are not supported if you are using an image from media manager.
1. use the image & links tab in your articles and roksprocket can use this and you will get an ALT tag.
OR
2. your can alter/create the roksprocket override for the layout/theme that you are using in the template that you are using. In that override you can write a little php to use the title field in roksprocket as the ALT tag as well as it's normal use as the title proper. I have done this before for several of our members and it's not a hard thing to do.
So, it's not a bug, it works as intended. and if you want option 2 above we can help you to achieve that to get the result that you want.
Posted 10 years 2 weeks ago #12275
Looking at it quickly, I think option 2 is the way to go. Can you please advise, thanks
by pacfood
Posted 10 years 2 weeks ago #12293
Hi, can I please get help with how to implement the below option:
Thanks
by pacfood
Posted 10 years 2 weeks ago #12294
Sorry, its your job, because we have currently no ressource to do any custom PHP programming.
