[SOLVED] Probleme fichier .php
- looping333
Topic Author
Hi ,
I come to you because I can not seem to solve the problem.
I do not have access to my .php files, I do not understand.
I install twice the Quickstar template INTERIOR set each time the prbleme back, I can not enter my .php file, they are there but I can not enter, I am sending you a screen for you to see problem.
thank you in advance for your help.
Cordially.
Cordially.
Last Edit:9 years 7 months ago
by looping333
Last edit: 9 years 7 months ago by looping333.
- Thank you received: 1740
Sorry, dont know what do you want with the "index.php" file in root folder.
Here is a breif instruction of the file structure which is important for customizing:
yootheme.com/themes/documentation/developers/file-structure
The following user(s) said Thank You: looping333
- looping333
Topic Author
Thank you for your link but I do not understand English and I am not étrise enough to understand the structures.
I want you to understand that if I want to edit a tag I can not, on the other sitesjoomla you can change from the administration, on the theme that I buy I can not because the .php file n is not complete.
Your help will be valuable to me please
I try to tell you that if you look at the picture, I do not see the WHOLE HOUSE file, with tags HEAD etc ...
I can not change because the file stops like the picture, we do not see all the tags and what PHP file should have.
in advance thank you sir.
Cordially.
Cordially.
by looping333
Hi again, you dont have to edit any PHP file.
What do you want to change? All things must be changed in the template options!
- looping333
Topic Author
hi
Thank you for your help.
I do not want to change.
for example between the HEAD tags, I will wish to google analytic, but the head tag is not visible on this theme.
cordially
cordially
by looping333
Insert your Google Analytics tracking code or any other additional scripts here.
>> Template Options > Settings > Additional Script See image below
They will be added before the closing body tag in the theme.
The second option is to add the code into the file > layouts > theme.php
Attachment google-2.jpg not found
Last edit: 9 years 7 months ago by joomlaplates.
