[SOLVED] Link images in Mosaic Sprocket Module to articles
Link images in Mosaic Sprocket Module to articles was created by giorgio
Posted 9 years 7 months ago #15129
Hi JoomlaPlates,
compliments for your Black&White Template, I like it very much for my small wedding website elemattesposi.it .
I'm writing to ask you how can I link the images in the Mosaic Sprocket Module directly to articles and not to the image pop-up, as it is the case already for the "read more" button and the title. How do I have to customize my css?
Thank you very much for your assistance,
best regards,
Giorgio
Last Edit:9 years 7 months ago by giorgio
Last edit: 9 years 7 months ago by giorgio. Reason: typing error
Replied by giorgio on topic Link images in Mosaic Sprocket Module to articles
Posted 9 years 7 months ago #15146
after backing-up the template, I tried a "brute force" solution (as I do not know neither css nor php codes).
I've modified JOOMLAROOT/templates/jp-bw/roksprocket/layouts/mosaic/themes/default/item.php
Instead of text in bold:
<div class="sprocket-mosaic-image-container">
<a href="<?php echo $item->getPrimaryImage()->getSource(); ?>" data-uk-lightbox title="<?php echo $item->getPrimaryImage()->getAlttext(); ?>"><img src="<?php echo $item->getPrimaryImage()->getSource(); ?>" alt="<?php echo $item->getPrimaryImage()->getAlttext(); ?>" class="hover-effect" />
<p class="view">+</p></a>
<a href="<?php echo $item->getPrimaryLink()->getUrl(); ?>" ><img src="<?php echo $item->getPrimaryImage()->getSource(); ?>" alt="<?php echo $item->getPrimaryImage()->getAlttext(); ?>" class="hover-effect" />
Then, as my "read more" link was no longer useful, I removed it simply by deleting the following line in bold:
<?php if ($item->getPrimaryLink()) : ?>
<a href="<?php echo $item->getPrimaryLink()->getUrl(); ?>" class="uk-button uk-button-primary"><span><?php rc_e('READ_MORE'); ?></span></a>
<?php endif; ?>
Now it appears to work just as I wanted to.
If a more elegant solution can better fulfill this task, I'll be glad to adopt it.
Thanks for your attention,
Giorgio
by giorgio
Replied by joomlaplates on topic Link images in Mosaic Sprocket Module to articles
Posted 9 years 7 months ago #15150
Yes youre right.
It was the right way to do it.
Customizing the override files are based on this folder:
Replied by joomlaplates on topic [SOLVED] Link images in Mosaic Sprocket Module to articles
Posted 9 years 7 months ago #15151
