[SOLVED] How to hide line between top-a and top-b
How to hide line between top-a and top-b was created by tstoneman
Posted 9 years 11 months ago #15223
I am using just the title in top-a on my home page. top-b will be used for a slider.
How does one hide the faint line or <hr> between the module rows top-a and top-b. I'm trying to tighten up the space, and can't find the code to modify. Also, I only want to do this between top-a and top-b, not the other module rows (top-c and top-d)
pmhs76.org (work in progress)
by tstoneman
Replied by tstoneman on topic How to hide line between top-a and top-b
Posted 9 years 11 months ago #15227
Update:
I found the following lines in the layouts/theme.php file (around line 99):
<!-- Top Module A B C D -->
<?php if ($this->count('top-a + top-b + top-c + top-d')) : ?>
<?php if ($this->count('top-a')) : ?>
<section class="<?php echo $grid_classes; ?>" data-uk-grid-match="{target:'> div > .uk-panel'}" data-uk-grid-margin><?php echo $this->render('top-a', array('layout'=>$this->get('grid.top-a.layout'))); ?></section>
<hr class="style-one">
<?php endif; ?>
<?php if ($this->count('top-b')) : ?>
So it looks like I can comment out the line with <hr class="style-one"> and the horizontal rule goes away.
My concern is if I do this, and the template is updated down the road, I assume I would loose the change and have to find it again.
Is there a way to make this change which would not be impacted down the road, similar to the custom.css files?
<?php endif; ?>
by tstoneman
Replied by joomlaplates on topic How to hide line between top-a and top-b
Posted 9 years 11 months ago #15230
You can hide the "hr" if you insert this code into your css/custom.css
hr.style-one {
height: 0;
background:none !important
Posted 9 years 11 months ago #15232
Won't that effect the <hr> lines between all the module rows, or any other place which calls out that class? I just want to remove the ruler between top-a and top-b. I do not want to remove the rulers between top-b and top-c or top-c and top-d, or any other instances.
by tstoneman
Posted 9 years 11 months ago #15263
Therefore you have to remove the "hr" code from layouts/theme.php
If you dont want to loose the customizing, please add you own theme.php to your default style folder:
Example:
template name/styles/blue/layouts/theme.php
Example:
The following user(s) said Thank You: tstoneman
Replied by tstoneman on topic [SOLVED] How to hide line between top-a and top-b
Posted 9 years 11 months ago #15264
by tstoneman
