Top menu active links "invisible"
  • iaspro
Top menu active links "invisible" was created by iaspro
Posted 8 years 11 months ago #17242
The top-menu item "News" is invisible when active: demo.joomlaplates.com/jp_fenya/joomla/jo...tegory-blog-2-column
That's because the link color is the same with the top-header background.
I found that the active link color can be changed by the "theme customizer->Typography->Link color" setting. But this setting affects the articles' text link color.
How can I set a specific link color for the top-menu items different than the articles' link color?
Last Edit:8 years 11 months ago by iaspro
Last edit: 8 years 11 months ago by iaspro.
Replied by joomlaplates on topic Top menu active links "invisible"
Posted 8 years 11 months ago #17243
Hi there, thanks for the tip.
You can add this code to your css/custom.css
.top-outer .uk-subnav > .uk-active > * {
color: #000 !important;
The following user(s) said Thank You: iaspro
  • iaspro
Replied by iaspro on topic Top menu active links "invisible"
Posted 8 years 11 months ago #17244
It worked!
(".toolbar-outer...")
Thank you!
joomlaplates wrote: Hi there, thanks for the tip.
by iaspro
