container width mainpage not changing
- dieverbindung
container width mainpage not changing was created by dieverbindung
Posted 5 years 7 months ago #23550
I am trying since hours to change the ratio width between the left and right main container.
As soon as I change the styles id="jp-left" in my browser manually it works fine.
When I change the width within the css code, it has no effekt in the frontend it is still 50%/50%
I was also looking within the template setup, remembered there was a lot of customizing, but also the sidebar changes had no effect.
looking for some help.
Almost similar issue in top-c region, here I have two columns and need to have a 100% width of the left container, so no content will overflow to the right one.
many thanks and best
Dave
Dave
Replied by joomlaplates on topic container width mainpage not changing
Posted 5 years 7 months ago #23568
you have to add this code into your css/custom.css
How to customize a theme
#jp-left { width:30%}
#jp-right {width:70%}
