[SOLVED] Adding a pulldown menu at the top left (toolbar-l)
Adding a pulldown menu at the top left (toolbar-l) was created by alainchammas
Posted 4 years 11 months ago #25332
In the Advokat theme, when I try to add a secondary menu at any other location than "menu" module position, I cannot have the submenus show when I hover over the menu (like in the main menu in the "menu" module position). When I select "Show Sub-menu Items" = Yes in the module configurator, the whole menu structure is displayed statically (not what we want). What do I have to change to get the result desired?
Last Edit:4 years 11 months ago by alainchammas
Last edit: 4 years 11 months ago by alainchammas.
Replied by joomlaplates on topic Adding a pulldown menu at the top left (toolbar-l)
Posted 4 years 11 months ago #25336
a dropdown menu is only possible in the menu position.
Accordion menu is possible only in sidebars and on all other module position there is only a basic menu without dropdown function.
Anyway you can add a custom html module with html code instead of a menu module on the position.
Therefore use the following code
getuikit.com/v2/docs/subnav.html
<ul class="uk-subnav">
<li><a href="">...</a></li>
<!-- This is the container enabling the JavaScript -->
<li data-uk-dropdown="{mode:'click'}">
<!-- This is the nav item toggling the dropdown -->
<a href="">...</a>
<!-- This is the dropdown -->
<div class="uk-dropdown uk-dropdown-small">
<ul class="uk-nav uk-nav-dropdown">
</ul>
</div>
</li>
</ul>
Replied by alainchammas on topic [SOLVED] Adding a pulldown menu at the top left (toolbar-l)
Posted 4 years 11 months ago #25357
Replied by alainchammas on topic Adding a pulldown menu at the top left (toolbar-l)
Posted 4 years 11 months ago #25358
Hello, Solved with a Custom module and the html instructions you sent, than you.
