Problem with Mosaic in Black/White Template
Problem with Mosaic in Black/White Template was created by opitzlein
Posted 6 years 8 months ago #25420
hI!
Can you help me?
If i want to open the mosaic Module, i get the message: 1104 The SELECT would examine more than MAX_JOIN_SIZE rows; check your WHERE and use SET SQL_BIG_SELECTS=1 or SET MAX_JOIN_SIZE=# if the SELECT is okay
What can i do to fix this? Site is: www.eyecatcher.at/eyecatcher2020
Thanks
Jörg
Can you help me?
Thanks
Jörg
by opitzlein
Replied by joomlaplates on topic Problem with Mosaic in Black/White Template
Posted 6 years 8 months ago #25431
seems to be an installation issue.
Please deinstall the roksprocket and install it again
Replied by opitzlein on topic Problem with Mosaic in Black/White Template
Posted 6 years 8 months ago #25461
Hi!
This is not the solution.
I deleted all form my server and my database and uploaded the quickstart package one more.
The same message: "1104 The SELECT would examine more than MAX_JOIN_SIZE rows; check your WHERE and use SET SQL_BIG_SELECTS=1 or SET MAX_JOIN_SIZE=# if the SELECT is okay"
Whats this?
Whats this?
by opitzlein
Posted 6 years 8 months ago #25463
Give me access to your site.
Send me the details via mail or WhatsApp
- meyer@gemos-management.de
Replied by meyer@gemos-management.de on topic Problem with Mosaic in Black/White Template
Posted 6 years 2 months ago #27075
The problematic query is the following:
The exception thrown is:
The underlying issue in this case will be, that the default for the
@@max_join_size
variable is not the factory shipped default of 18446744073709551615, but has been altered (probably by the provider, if you don't own the server) to something much lower, like 201326592.
Because of missing indices, MySQL has to retrieve the data from the 10 referenced tables as a cartesian product, which could have the potential to be temporarily larger than @@max_join_size.
To fix this, you can set @@max_join_size to the factory default value of 18446744073709551615:
Alternatively, set @@sql_big_selects to 1:
Executing one of those two statements at any time before the failing query (on the same connection), should be enough.
SELECT a.id, a.title, a.alias, a.introtext, a.`fulltext`, a.catid, a.state, a.access, a.created, a.created_by, a.created_by_alias, a.modified, a.featured, a.language, a.hits, a.publish_up, a.publish_down, a.images, a.urls, a.language, a.metakey, a.metadesc, a.metadata,c.title AS category_title, c.alias AS category_alias,ua.name AS author_name,um.name AS last_modified_by,ROUND(v.rating_sum / v.rating_count, 0) AS rating, v.rating_count as rating_count,vl.title AS access_title,l.title AS language_title
FROM #__content as a
LEFT JOIN #__categories AS c ON c.id = a.catid
LEFT JOIN #__users AS ua ON ua.id = a.created_by
LEFT JOIN #__users AS um ON um.id = a.modified_by
LEFT JOIN #__content_rating AS v ON a.id = v.content_id
LEFT JOIN #__viewlevels AS vl ON a.access = vl.id
LEFT JOIN #__languages AS l ON a.language = l.lang_code
LEFT JOIN #__contentitem_tag_map AS ct ON ct.content_item_id = a.id
LEFT JOIN #__tags AS t ON t.id = ct.tag_id
LEFT OUTER JOIN (select rsi.provider_id, rsi.order from #__roksprocket_items as rsi where module_id = 209) rsi on a.id = rsi.provider_id
WHERE ((a.access IN(1,1,2,3) AND (a.state != -2)) AND a.id IN (0)) OR ((a.access IN(1,1,2,3) AND (a.state != -2)) AND a.catid IN (91))
GROUP BY id
ORDER BY IF(ISNULL(rsi.order),1,0),rsi.order
JDatabaseExceptionExecuting: The SELECT would examine more than MAX_JOIN_SIZE rows; check your WHERE and use SET SQL_BIG_SELECTS=1 or SET MAX_JOIN_SIZE=# if the SELECT is okay in /website_path/libraries/joomla/database/driver/mysqli.php:665
Stack trace:
#0 /website_path/libraries/joomla/database/driver.php(1701): JDatabaseDriverMysqli->execute()
#1 /website_path/components/com_roksprocket/lib/RokSprocket/Provider/AbstarctJoomlaBasedProvider.php(61): JDatabaseDriver->loadObjectList('id')
#2 /website_path/components/com_roksprocket/lib/RokSprocket.php(294): RokSprocket_Provider_AbstarctJoomlaBasedProvider->getItems()
#3 /website_path/components/com_roksprocket/lib/RokSprocket.php(230): RokSprocket::getItems(Object(RokSprocket_Provider_Joomla), '209', Array, NULL, 'manual', 'after', false, true, Array)
#4 /website_path/administrator/components/com_roksprocket/models/module.php(1072): RokSprocket::getItemsWithParams('209', Object(RokCommon_Registry), false, true)
#5 /website_path/administrator/components/com_roksprocket/views/module/view.html.php(56): RokSprocketModelModule->getArticles('209', Array)
#6 /website_path/libraries/src/MVC/Controller/BaseController.php(672): RokSprocketViewModule->display()
#7 /website_path/administrator/components/com_roksprocket/controller.php(77): Joomla\CMS\MVC\Controller\BaseController->display()
#8 /website_path/libraries/src/MVC/Controller/BaseController.php(710): RokSprocketController->display()
#9 /website_path/administrator/components/com_roksprocket/roksprocket.php(28): Joomla\CMS\MVC\Controller\BaseController->execute('')
#10 /website_path/libraries/src/Component/ComponentHelper.php(402): require_once('/website_path/...')
#11 /website_path/libraries/src/Component/ComponentHelper.php(377): Joomla\CMS\Component\ComponentHelper::executeComponent('/website_path/...')
#12 /website_path/libraries/src/Application/AdministratorApplication.php(101): Joomla\CMS\Component\ComponentHelper::renderComponent('com_roksprocket')
#13 /website_path/libraries/src/Application/AdministratorApplication.php(159): Joomla\CMS\Application\AdministratorApplication->dispatch()
#14 /website_path/libraries/src/Application/CMSApplication.php(196): Joomla\CMS\Application\AdministratorApplication->doExecute()
#15 /website_path/administrator/index.php(51): Joomla\CMS\Application\CMSApplication->execute()
#16 {main}
set @@max_join_size = 18446744073709551615;
set @@sql_big_selects = 1;
Last Edit:6 years 2 months ago
Last edit: 6 years 2 months ago by meyer@gemos-management.de.
