[SOLVED] Content Appearing in Breadcrumbs
  • tmichel
  • tmichel's Avatar Offline Topic Author
  • Thank you received: 1
Content Appearing in Breadcrumbs was created by tmichel
Posted 4 years 10 months ago #25620
See:
I don't want Joomla content to appear in Breadcrumbs, but rather where it should appear between main-top and main-bottom, but I don't seem to be able to figure out where to set this.
by tmichel
Replied by joomlaplates on topic Content Appearing in Breadcrumbs
Posted 4 years 9 months ago #25621
the word "home" is not a breadcrumb. its based on the menu item configuration > Page Title
www.joomlaplates.com/support/documentati...hange-the-page-title
BTW I cant see any breadcrumb module on your site. The breadcrumbs are always above the Joomla system output.
  • tmichel
Replied by tmichel on topic Content Appearing in Breadcrumbs
Posted 4 years 9 months ago #25635
Last Edit:4 years 9 months ago by tmichel
Last edit: 4 years 9 months ago by tmichel.
  • tmichel
Posted 4 years 9 months ago #25639
I don't know how this happened, but it prevents front end editing. If this were a standard Joomla template and not a WARP template, I would assume that there was a missing closing bracket in the template index.php file, but this isn't a standard Joomla template so I need some help in understanding how it is that content, or the Joomla Component, came to be displayed in the Breadcrumbs position; it should be in Joomla Component position. between Main Top and Main Bottom.
by tmichel
Posted 4 years 9 months ago #25647
If you dont like the breadcrumbs module, you can disbale the module on the home page.
  • tmichel
Posted 4 years 9 months ago #25650
If I disable Bread Crumbs, the Joomla Component is still displayed in Breadcrumbs. If I need to edit the PHP just point me to the right file and I will do that. I need the Joomla Component to be displayed independent of module position, in fact in the Joomla Component position. When I write my own templates I select where in the page I want the Joomla component to appear. This is my first time using the Warp engine, and I am pretty impressed except for this one little wrinkle. Really allows us to organize the page styles in a structured way
The Joomla Component shouldn't be displayed in bread crumbs, I must have screwed something up when initially installing the template. I need to fix this now, any ideas??
I have a "Photos" page where I installed my own component that doesn't display the Joomla component and the breadcrumbs works properly. this is how I want all pages to look. Yes I did this before I realized that the Wrap engine allows us to create styles where I can select to not display the Joomla Content. But I have already used this method before realizing that.
