[SOLVED] Sticky menu don't work
the sticky menu works fine in the homapage, but not in other pages.
What's the problem?
(thanks!)
Jo
please delete all layouts you dont need
www.joomlaplates.com/support/documentation/warp-7-layouts
The layout settings manage the positioning of different layout parts.
This section makes the arrangement of your content very easy and flexible. You can enable or disable system output, define the layout of the theme's widget or module positions and select a style you created in the customizer. Additionally you have the possibility to store your modifications in a layout profile and assign it to different pages.
In "options" in my template> "navigation", I don't flag the fixed navigation option...but nothing happens
You advise me to delete the layouts that I don't use... but I don't know how I can delete the layouts...I go to template (settings area)> layouts> I have 2 options: default and "startsite"...
I need your help for this sticky menu!
Thanks!
About the visibility for article in home page, now I work with "hide system output" option, and I set all the homepage with modules, and this works fine.
delete the layout "startseite"
And now take a look in the settings, if the sticky menu is enabled
thanks, I delete the startsite layout...but unfortunately the sticky menu doesn't work.
The setting for fixed menu is not enabled...
The other problem is that the customizer doesn't work.
Thanks
please enable this, its the stick menu
