[SOLVED] Problems with pagination on smartphones
- RG-Consultant
- Junior Boarder
Problems with pagination on smartphones was created by RG-Consultant
Posted 4 years 4 months ago #29823
A member of forum.joomla.fr found a pagination problem (blog page) with Cassiopeia. I have the same with TP Brush.
On smartphone the pagination line overflows to the right and creates an empty column above the last digits.
You can see it on my site les-couteaux.de-ergé.fr At the top, scroll left and you see the empty column. At the bottom you can see the overflow of the pagination.
A thread and perhaps a solution on the last page (I didn't try as I just discover it on my site) here: forum.joomla.fr/forum/joomla-4-x-aa/ques...-template-cassiopeia
Regards,
Robert
Regards,
Robert
Last Edit:4 years 4 months ago
by RG-Consultant
Last edit: 4 years 4 months ago by RG-Consultant.
Replied by joomlaplates on topic Problems with pagination on smartphones
Posted 4 years 4 months ago #29829
add this code to your custom.css
.pagination {
display: flex;
flex-wrap: wrap;
- RG-Consultant
- Junior Boarder
Replied by RG-Consultant on topic Problems with pagination on smartphones
Posted 4 years 4 months ago #29832
Perfect!
Thanks!
Thanks!
- RG-Consultant
- Junior Boarder
Replied by RG-Consultant on topic [SOLVED] Problems with pagination on smartphones
Posted 4 years 4 months ago #29833
