[SOLVED] Problem with opffcanvas menu
Problem with opffcanvas menu was created by griffin
Posted 4 years 3 months ago #30002
i have a problem with the offcanvas menu on Hope template. I don't see a way to disable them in small devices, and in mobile phones two menus cover at the same time. Thanks for the help!
by griffin
Replied by griffin on topic Problem with opffcanvas menu
Posted 4 years 3 months ago #30003
SOLVED - I find the settings at ASTRIOD settings > "HEADER"
I set "off" at the mobile menu. Offcanvas works fine on mobile devices.
Thanks!
by griffin
Replied by griffin on topic [SOLVED] Problem with opffcanvas menu
Posted 4 years 3 months ago #30004
by griffin
