[SOLVED] Lokale Fonts + PHP8: Path cannot be empty
- creativeservices
Lokale Fonts + PHP8: Path cannot be empty was created by creativeservices
Posted 1 year 11 months ago #32901Code:
ValueError:
at [webroot]/libraries/astroid/framework/library/FontLib/BinaryStream.php:110
at fopen()
([webroot]/libraries/astroid/framework/library/FontLib/BinaryStream.php:110)
at FontLib\BinaryStream::getTempFile()
([webroot]/libraries/astroid/framework/library/FontLib/WOFF/File.php:36)
at FontLib\WOFF\File->load()
([webroot]/libraries/astroid/framework/library/FontLib/Font.php:67)
at FontLib\Font::load()
([webroot]/libraries/astroid/framework/library/astroid/Helper/Font.php:136)
at Astroid\Helper\Font::getLocalFonts()
([webroot]/libraries/astroid/framework/library/astroid/Helper/Font.php:123)
at Astroid\Helper\Font::getUploadedFonts()
([webroot]/libraries/astroid/framework/library/astroid/Template.php:311)
at Astroid\Template->getFonts()
([webroot]/libraries/astroid/framework/library/astroid/Helper/Font.php:257)
at Astroid\Helper\Font::loadLocalFont()
([webroot]/libraries/astroid/framework/library/astroid/Helper/Font.php:208)
at Astroid\Helper\Font::getFontFamily()
([webroot]/libraries/astroid/framework/library/astroid/Helper/Style.php:290)
at Astroid\Helper\Style::getFontFamilyValue()
([webroot]/libraries/astroid/framework/library/astroid/Helper/Style.php:278)
at Astroid\Helper\Style::renderTypography()
([webroot]/libraries/astroid/framework/library/astroid/Component/Utility.php:199)
at Astroid\Component\Utility::typography()
([webroot]/templates/tp_advocat/error.php:28)
at require('[webroot]/templates/tp_advocat/error.php')
([webroot]/libraries/src/Document/HtmlDocument.php:737)
at Joomla\CMS\Document\HtmlDocument->_loadTemplate()
([webroot]/libraries/src/Document/HtmlDocument.php:792)
at Joomla\CMS\Document\HtmlDocument->_fetchTemplate()
([webroot]/libraries/src/Document/HtmlDocument.php:609)
at Joomla\CMS\Document\HtmlDocument->parse()
([webroot]/libraries/src/Document/HtmlDocument.php:627)
at Joomla\CMS\Document\HtmlDocument->render()
([webroot]/libraries/src/Document/ErrorDocument.php:139)
at Joomla\CMS\Document\ErrorDocument->render()
([webroot]/libraries/src/Error/Renderer/HtmlRenderer.php:78)
at Joomla\CMS\Error\Renderer\HtmlRenderer->render()
([webroot]/libraries/src/Exception/ExceptionHandler.php:121)
at Joomla\CMS\Exception\ExceptionHandler::render()
([webroot]/libraries/src/Exception/ExceptionHandler.php:72)
at Joomla\CMS\Exception\ExceptionHandler::handleException()
([webroot]/libraries/src/Application/CMSApplication.php:322)
at Joomla\CMS\Application\CMSApplication->execute()
([webroot]/includes/app.php:61)
at require_once('[webroot]/includes/app.php')
([webroot]/index.php:32)
Wenn ich eine Google-Font wähle, geht alles. Wenn ich eine lokale Custom-Font wähle, kommt der Fehler in PHP
Problem tritt auf bei:
- PHP 8.1.18
- jos 4.2.9 / 4.2.0
- Astroid 2.6.4
- tp_advocat 1.3.13,
im Backend, wenn ein Frontend-Templatestil bearbeitet werden soll (Einlesen der Fonts) und
direkt im Frontend.
Auslöser war, so weit beobachtbar, ein Update von tp_advocat 1.3.12 auf tp_advocat 1.3.13 oder astroid auf 2.6.4.
System- und Astroid-Cache leeren und System-Cache deaktivieren brachte nix. Kurz Umstellen auf PHP 7.4 war erfolgreich, ist aber keine Option.
Last Edit:1 year 11 months ago
by creativeservices
Last edit: 1 year 11 months ago by creativeservices.
Replied by WM-Loose on topic Lokale Fonts + PHP8: Path cannot be empty
Posted 1 year 11 months ago #32902
Danke für den eigenen Topic.
Stimmt der Zielordner für die Ablage der lokalen Fonts:
media/templates/site/template_name/fonts
Eventuell im BE bei 'System-Konfiguration-Server'
'Fehler berichten' auf '
'Keine'
'Keine'
Last edit: 1 year 11 months ago by WM-Loose.
- creativeservices
Replied by creativeservices on topic Lokale Fonts + PHP8: Path cannot be empty
Posted 1 year 11 months ago #32903
Der Pfad stimmt, denn die Fonts sind im BE wählbar. Auch die fs-Rechte sind korrekt. Das FE wirft einen 500, macht also die Seite unbrauchbar. Es wird folglich dringend eine Lösung benötigt, da PHP7.4 nicht mehr betrieben werden soll. Und es sind sämtliche CMS im Bestand betroffen, die alle auf jos4 + jp-tpl/astroid laufen.
Und da es Produktivsysteme sind, ist error reporting sowieso aus. Die Ausgabe oben war im Entwicklungsbereich mit "maximal".
by creativeservices
Posted 1 year 11 months ago #32904
Ok, dann bitte Fehleranalyse durchführen:
forum.joomla.de/thread/6467-fehler-finde...ug-modus-call-stack/
- creativeservices
Posted 1 year 11 months ago #32905
call stack siehe oben.
Posted 1 year 11 months ago #32906
Seite lokal oder online?
