[SOLVED] Install jpfile problem with joomla 4
[SOLVED] Install jpfile problem with joomla 4 was created by itbilling
Posted 1 year 9 months ago #33163
Hi All
we try to install joomla 4, but we meet a problem with jpfile template.
So i uninstall roksprotect because is off date.
Finaly joomla has been install, and only backoffice worked, front office had an error:
Warning: Trying to access array offset on value of type int in/home/lerablingtest/public_html/templates/jp-life/warp/src/Warp/Config/Repository.php on line 243
Joomlaplates support explained to me that warp was no longer used by the new jpfile version.
So i decided to uninstalled jpfile and follow what it explained in their website.
1/ I installed astroid,
2/ then uikit3 plugin
3/ jpfile template
and at the end of installation i had this 2 errors messages:
JInstaller::instal: can't find xml setup file
Unable to detect manifest file
Is one of you have any idea about where come from the problem?
Thanks in advance for you help.
Replied by joomlaplates on topic [SOLVED] Install jpfile problem with joomla 4
Posted 1 year 9 months ago #33167
Please read the instruction how to install the template.
Maybe you tried to install the wrong file
www.joomlaplates.de/template-installation/ordner-struktur.html
Replied by Administrator on topic [SOLVED] Install jpfile problem with joomla 4
Posted 1 year 9 months ago #33168
Last Edit:1 year 9 months ago by Administrator
Last edit: 1 year 9 months ago by Administrator.
Replied by itbilling on topic [SOLVED] Install jpfile problem with joomla 4
Posted 1 year 9 months ago #33172
Thank you,
it's that I did, as i wrote, i followed the instructions.
But not works.
Posted 1 year 9 months ago #33173
Hi
Is the astroid and uikit must have to be installed under joomla3 then update joomla to version4 or must be installed after the joomla update had been done?
Because if we try to update joomla3 to 4 with the current version of your template with rokprotect, the update is impossible, migration doesn't work.
Could you clarify please?
thanks
Posted 1 year 9 months ago #33174
Hello,please follow this instructions
www.joomlaplates.de/joomla-tips-und-tricks/joomla-4-faq.htm
lAnd Astroid and the theme should be installed before updating
[hr]
