[SOLVED] Slideshow 1.2.3 module
Good morning
I use the Article Slideshow 1.2.3 module for joomla 4.4.5
I would like the DotNavs to be black with a white background so that they are more visible.
Is it possible for you to send me the CSS code to take action?
Thanks in advance
Best regards
Thanks in advance
Best regards
Last Edit:1 year 9 months ago
by IDTK
Last edit: 1 year 9 months ago by IDTK.
by IDTK
All currently turquoise buttons are set to the color Primary in the template options.
There you can simply change the color Primary to white.
This will then take all buttons into account.
More documentation look here an translate from geman in your language...
Farben /Colors
Farben /Colors
Last edit: 1 year 9 months ago by WM-Loose.
Sorry, I explained myself incorrectly: I thought "dotnav" referred to the arrows and not the points under the slide.
I am attaching an image for more understanding.
Thanks in advance
Thanks in advance
by IDTK
Ahh ok.
uk-slidenav:hover {
color: rgb(1, 1, 1);
uk-slidenav: {
.uk-icon {
background-color: #fff;
uk-slidenav:hover {
uk-slidenav: {
.uk-icon {
The following user(s) said Thank You: joomlaplates, IDTK
