[SOLVED] UIkit 3 Grid Portfolio - "Limit" problem
Replied by karaspr on topic UIkit 3 Grid Portfolio - "Limit" problem
Posted 6 days 8 hours ago #35180
[SOLVED] Error was because of maximum entry length limit in database. After modification of one line in module.php file (checking entry length) and change of types of two columns in database from TEXT to MEDUIMTEXT problem stoped for now.
So it WAS a module problem (limit) in fact.
Last Edit:6 days 7 hours ago
by karaspr
Last edit: 6 days 7 hours ago by karaspr.
Replied by WM-Loose on topic UIkit 3 Grid Portfolio - "Limit" problem
Posted 6 days 6 hours ago #35181
Thanks for pointing this out. We will check it.
Last Edit:6 days 5 hours ago
Last edit: 6 days 5 hours ago by WM-Loose.
- Thank you received: 1730
Replied by joomlaplates on topic [SOLVED] UIkit 3 Grid Portfolio - "Limit" problem
Posted 6 days 6 hours ago #35182
Hello, thanks for info.
But there is no module.php file in the grid portfolio module!!!
What did you cahnge and in which module?
Thanks Peter
Thanks Peter
Last Edit:8 hours 21 minutes ago
Last edit: 8 hours 21 minutes ago by WM-Loose.
