[SOLVED] RockSprocket-Theme
Replied by ofv1907 on topic RockSprocket-Theme
Posted 7 years 2 months ago #24199
Das Schnipsel ist drin - meine ich!? Es öffnet das PopUp-Fenster und der Inhalt zeigt die komplette Website - nicht den angesprochenen Beitrag.
Anbei der Script:
<?php
* @version $Id: item.php 10885 2013-05-30 06:31:41Z btowles $
* @author RocketTheme www.rockettheme.com
* @copyright Copyright (C) 2007 - 2014 RocketTheme, LLC
* @license www.gnu.org/licenses/gpl-2.0.html GNU/GPLv2 only
<div class="sprocket-strips-c-block" data-strips-item>
<!--Plain-->
<?php if (!$item->getPrimaryImage()) :?>
<div class="plain">
<?php endif; ?>
<!--Plain-->
<div class="sprocket-strips-c-item" data-strips-content>
<?php if ($item->getPrimaryLink()) : ?>
<img src="<?php echo $item->getPrimaryImage()->getSource(); ?>" alt="<?php echo $item->getPrimaryImage()->getAlttext(); ?>" class="sprocket-mosaic-image" />
<?php endif; ?>
<div class="sprocket-strips-c-content">
<?php if ($item->getTitle()) : ?>
<h4 class="sprocket-strips-c-title" data-strips-toggler>
<?php if ($item->getPrimaryLink()) : ?><a href="<?php echo $item->getPrimaryLink()->getUrl(); ?>"><?php endif; ?>
<?php echo $item->getTitle();?>
<?php if ($item->getPrimaryLink()) : ?></a><?php endif; ?>
</h4>
<?php endif; ?>
<div class="sprocket-strips-c-extended">
<div class="sprocket-strips-c-extended-info">
<?php if ($item->getText()) :?>
<span class="sprocket-strips-c-text">
<?php echo $item->getText(); ?>
</span>
<?php endif; ?>
<a data-lightbox-type="iframe" data-uk-lightbox="{group:'<?php echo $item->getPrimaryImage()->getAlttext(); ?>'}" href="<?php echo $item->getPrimaryLink()->getUrl(); ?>?tmpl=component" class="uk-button"><span><?php rc_e('READ_MORE'); ?></span></a>
<?php endif; ?>
</div>
</div>
</div>
</div>
<!--Plain-->
</div>
<?php endif; ?>
<!--Plain-->
</div>
Last Edit:7 years 2 months ago by ofv1907
Last edit: 7 years 2 months ago by ofv1907.
Replied by joomlaplates on topic RockSprocket-Theme
Posted 7 years 2 months ago #24201
Benutzen sie mal folgenden Code, getestet und geht.
<?php
* @copyright Copyright (C) 2007 - 2015 RocketTheme, LLC
<li class="sprocket-strips-s-block" data-strips-item>
<div class="sprocket-strips-s-item" data-strips-content>
<?php if ($item->getPrimaryImage()) :?>
<div style="overflow:hidden">
<img class="hover-effect border" src="<?php echo $item->getPrimaryImage()->getSource(); ?>" alt="<?php echo $item->getPrimaryImage()->getAlttext(); ?>" />
</div>
<?php endif; ?>
<div class="sprocket-strips-s-content">
<h4 class="sprocket-strips-s-title" data-strips-toggler>
</h4>
<?php endif; ?>
<span class="sprocket-strips-s-text">
</span>
<?php endif; ?>
<?php if ($item->getPrimaryLink()) : ?></br>
<?php endif; ?>
</div>
</div>
</li>
Posted 7 years 2 months ago #24203
Leider bei mir immer noch nicht. Die einzelnen Carden werden nun im Vollbildmodus dargestellt. Das PopUp-Fenster öffnet, aber wieder mit dem Inhalt der vollem Website. Warum auch immer es nicht funktionieren will.
Habe es auch mit Ihrer Demo-Seite getestet. Dort funktioniert es auch.
by ofv1907
Posted 7 years 2 months ago #24204
Eventuell liegt es an den SEO Einstellungen von Joomla! Schalten sie dies mal ab.
Posted 7 years 2 months ago #24208
Daran liegt es auch nicht. Vielleicht liegt es daran, ich benutze JP-Hotel mit dem RockSprocket-Theme vom JP-Power. Das Layout funktioniert nur das PopUp will nicht. Im Demo funktioniert es, dort ist SEO auch aktiv.
by ofv1907
Posted 7 years 2 months ago #24216
Ich habe nocheinmal verschiedenen Zenarien getestet. Der Script - den ich Ihnen oben hinterlegt habe- funktioniert soweit (PopUp-Fenster öffnet), nur der Fenster-Inhalt zeigt die komplette Website an (nicht den angesprochenen Beitrag).
Ich habe es auch in der Demo-Version getestet. Dort funktioniert alles prima. Beim Vergleich der Verlinkungen zeigt es bei mir eine andere Linkzeichen-Verkettung als in der Demo-Version (vermutlich liegt es daran).
Mein PopUp-Link … href="/?view=article&amp;id=133:egon-kahles&amp;catid=42:informationen?tmpl=component“
Demo-Seite … href="/index.php/kategorie-demo-artikel/61-egon-kahles?tmpl=component“
Die Beiträge in der Demo-Verion sind aber wie bei mir in Kategorien hinterlegt. Woran kann es liegen?
