[SOLVED] Module position-not-present
  • Milian
[SOLVED] Module position-not-present was created by Milian
Posted 2 years 5 months ago #33731
 I have place the Classic template in an existing website.
All works fine except one issue:
When I set the url to xxx?tp=1 .  I see a not existing Position.
See the url and the attachment.
sdtools.nl/ja40-classic/?tp=1
I do not find this in the mySql nore in the template code.
Hope somewone recognizes what it is an knows how tho remove it.
Thanks and regards,
Milian
by Milian
Replied by Administrator on topic [SOLVED] Module position-not-present
Posted 2 years 5 months ago #33735
Stell mal im Framework bei Header die Felder auf Leer.
Das passiert, wenn dort Modulposition ausgewählt wird, darunter dann aber keine Modulposition angegeben wird:
Last Edit:2 years 5 months ago by Administrator
Last edit: 2 years 5 months ago by Administrator.
  • Milian
Replied by Milian on topic [SOLVED] Module position-not-present
Posted 2 years 5 months ago #33736
Many thanks JP for the useful answer!
This was the solution.
Regards,
Milian
by Milian
Posted 2 years 5 months ago #33737
Sorry. I was in the German language.
Glad it works. :-)
